gjn200
| posted on 29/8/02 at 08:58 PM |
Sierra Half shafts
Apparently for the avon you need the smaller diameter (hub end)? Eh? Can anybody shed some light on this? Ta
Graham
P.s.
Don't suppose anybodys got/used/seen the custom autotech digital dash have they?
paulbeyer
| posted on 29/8/02 at 09:38 PM |
Graham
I think Jon Ison has a Autotech digi dash in his rice burner.
Viper
| posted on 25/10/02 at 08:56 PM |
Shafts
The sierra 1.6 and 2.0 share the same size shafts (small ones) the cossie and xr4x4 use the bigger shafts with bolt together Cv joints, i think the
later (ie disc braked) 2.0ltr models had the larger shafts. if you wanted to run discs the cossie runs larger discs than tho others and has a
different carrier to suit.
Hope this helps
