Barksavon
| posted on 19/12/10 at 07:04 PM |
Avon engine mounts
Do Tiger supply 2 different thickness rubber pinto engine mounts for the Avon simply to set the engine at an angle to allow side draught carbs to
clear the top chassis rail ...... or is there a more technical reason
Tiger Super Six
| posted on 19/12/10 at 10:48 PM |
Is it on a pinto? I didn't build mine but it did have two different height mounts. I recently levelled them to both be the higher size.
Mark
Tiger Avon
Barksavon
| posted on 20/12/10 at 09:18 AM |
yes its a Pinto, ive now fitted bike carbs which dont and wouldnt foul the chassis rail so i'm going to level the engine by fitting 2 same
thickness engine mounts...where did you get your replacement from or do you want to get rid of the one youve replaced ???
melly-g
| posted on 20/12/10 at 10:55 AM |
When I fitted my Pinto I dont remember the rubber mounts being different sizes!
Mine sits on an angle though, I thought it was the steel mounts that made the difference?
[Edited on 20/12/10 by melly-g]
sm1ggles
| posted on 6/1/11 at 08:49 PM |
engine mounts
rubber bushes on my tiger cat were the same size the plates on the chassis were not in line
melly-g
| posted on 5/3/11 at 08:39 PM |
your right the mounts are different! Had to have ny engine out to replace clutch and found the mounts were different I was probably lucky I got them
the right way round for the carb fitment over the top rail!
DaveFJ
| posted on 7/3/11 at 11:23 AM |
yup the steel mounts are different sizes..
I bought a thinner rubber mount for one side to make the engine sit nice and level
Dave
