Author: Subject: Avon Fuel Tank Sizes?
wombat
posted on 7/8/11 at 10:38 AM Reply With Quote
Hi, Can anyone supply me with sizes, and a picture if possible, of an Avon fuel tank.
Going to run Zetec on TB's.
Strontium Dog
posted on 7/8/11 at 11:20 AM Reply With Quote
Here you go!
You will need to use a swirl pot with a standard tank and injection too
[Edited on 7/8/11 by Strontium Dog]
http://s187.photobucket.com/albums/x319/zephyr2000/General%20forum%20uploads/?action=view¤t=3DEngine.mp4
laptoprob
posted on 7/8/11 at 11:49 AM Reply With Quote
And a low pressure lift pump too for the swirl pot.
Better still...just get a good one made with a baffle in it and your sorted
http://www.youtube.com/watch?v=ajlF4nWJtGA
wombat
posted on 7/8/11 at 07:21 PM Reply With Quote
Thanks for reply, being a bit thick but where should the baffle be (apart from inside tank..) and what size swirl pot?
laptoprob
posted on 8/8/11 at 04:08 PM Reply With Quote
SM Engineering alloy swirl pot, unused | eBay
The baffle goes inside the tank quite close to the fuel pick pipe. It will try to keep a good level of fuel around the pipe for a short time to prevent starvation in mid cornering which is what mine suffered with when i first fitted the a similar setup to my Avon. I took it for granted that Tiger would have fitted one from standard but they dont.
I now have a low pressure pump that lifts fuel from the tank to the swirl pot then the high pressure pump takes over from there.
wombat
posted on 9/8/11 at 06:33 AM Reply With Quote
Thx laptop, can I be cheeky and ask what pumps you use?
Cheers again.
laptoprob
posted on 9/8/11 at 08:43 AM Reply With Quote
Sure mate....
Fuel Pump 2.5-5.5 PSI Low Press -Ideal for Weber Carbs! | eBay
SYTEC IN LINE HIGH PRESSURE FUEL INJECTION PUMP 250BHP | eBay
wombat
posted on 10/8/11 at 05:51 AM Reply With Quote
Excellent, cheers buddy !
