Four Litre
| posted on 7/11/11 at 10:29 PM |
Tiger Avon Wheel Size?
Firstly hi to everyone on here....can see me coming here quite a bit in the next few months!
I've bought a tiger avon, but needs a bit of work as it hasn't had the best start in life... I'm aware that the car should have
either 14" or 15" wheels but mine has 13" - the fronts fit fine but the backs stand proud of the wheel arch (mounted on a sierra
drum). I've been looking on eBay and seen quite a few ford wheels but am not sure of the correct size width and offset.
Should the wheels be staggered?
Any help on this would be most appreciated..
Cheers all.
laptoprob
| posted on 8/11/11 at 07:57 AM |
They were offered to take 14" wheels which a good friend of mine has fitted but a little later they were offered with 15`s which i have and to
be honest look much better.
You need 38mm offset or 35mm(mine) will do. 195/50/15 tyres.
There are loads of people who have fitted larger width tyres and modded arches etc but to be honest i use mine for track 60% and the grip is
fantastic.
http://www.youtube.com/watch?v=ajlF4nWJtGA
JacksAvon
| posted on 8/11/11 at 10:15 AM |
If you intend racing the car stick with the 13" and find a set with the right offset, far better choice of rubber
Four Litre
| posted on 9/11/11 at 10:42 AM |
Guys - cheers for all the info - as its going to be mainly for the road I will probably go down the 15" route.
Is there a particula width I should be considering for the wheel, Tyres are fine with 195/50/15 but what is the correct wheel size for a 35 offset?
Im really after the width?
[Edited on 10/11/11 by Four Litre]
