richardh
posted on 2/12/13 at 09:03 AM |
Indicator on - no flash - constant buzzing
This should be easy but i cant figure out what's wrong. (electrics not my thing)
Hazards flash and work fine
Left indicators work fine, tick tick usual noise
Right indicators don't flash but the dash light is lit but the tick tick is now a constant very loud buzzing.
Any ideas folks please?
Time for a change!
Norfolkluegojnr
posted on 2/12/13 at 09:18 AM |
had this exact issue - side repeater wire had come loose.
check the side repeater on the side it isn't working on, bet that's your issue. ![](/images//smilies/smile.gif)
richardh
posted on 2/12/13 at 09:22 AM |
cheers,will do
Time for a change!
r1_pete
posted on 2/12/13 at 11:35 AM |
Check the wattage on the right side bulbs are not lower than the left too.
scudderfish
posted on 2/12/13 at 01:18 PM |
You say it doesn't flash, but you don't say if it lights. If it doesn't light, you have a short to earth somewhere in that circuit.
big-vee-twin
posted on 2/12/13 at 06:52 PM |
Could also be dirty switch, especially if your using a Sierra one, take apart and clean, had this giving similar probs.
http://www.triangleltd.com
ReMan
posted on 2/12/13 at 09:16 PM |
One bulb blown on that side, check them all, ant the earths if its a combo rear light
www.plusnine.co.uk
richardh
posted on 3/12/13 at 02:16 PM |
exactly as above, all working now. Cheers
Time for a change!
Norfolkluegojnr
posted on 3/12/13 at 03:53 PM |
which one?
richardh
posted on 3/12/13 at 03:57 PM |
one bulb rusted to bits - glass was separated
one had bad earth wire - well actually no wire
last one the bulb wasnt actually in its slot as the little metal lugs were bent over
Time for a change!
Norfolkluegojnr
posted on 3/12/13 at 04:00 PM |
Huzzah! we were all right! ![](/images//smilies/bigsmile.gif)
richardh
posted on 3/12/13 at 04:08 PM |
weird eh!
big thanks to all
Time for a change!
