Author: Subject: Fibre glass bath repair
mookaloid
posted on 24/1/14 at 06:55 PM Reply With Quote
Has anyone done this satisfactorily?
It is fibre glass and it has had a knock in one corner and the gel coat has cracked.
If I slap lots of mat underneath the area, then gently clean out the crack in the gel coat with the dremel, then repair the gel coat with this stuff Plastic padding
will it be a lasting repair?
Mark
cliftyhanger
posted on 24/1/14 at 07:49 PM Reply With Quote
Yes, exactly how I repaired a bath 10 years ago, still fine. And that is in a rental house of sharers (probably at bathtime too......)
You can use fine wet and dry, then cutting compound to finish and give a virtually invisible repair.
cliftyhanger
mookaloid
posted on 24/1/14 at 08:08 PM Reply With Quote
Cool thanks
plentywahalla
posted on 24/1/14 at 09:53 PM Reply With Quote
Are you sure its all fibreglass? Most baths today are heat formed from acrylic sheet and then reinforced by laminating GRP on the reverse. A completely invisible repair using polyester gel will be almost impossible to achieve in acrylic.
Rules are for the guidance of wise men ... and the obedience of fools. (anon)
jacko
posted on 25/1/14 at 12:03 PM Reply With Quote
Buy a new bath you tight sod
I bet Louise would rather have a new bath
mookaloid
posted on 26/1/14 at 01:07 AM Reply With Quote
After a bit of research I think it probably is Acrylic however I found this stuff http://www.bathtubrepair.co.uk/ so I'll give it a go.
