richardh
posted on 23/9/15 at 02:19 PM |
IVA Test Centres
Hi, I'm trying to find a list of test centres for IVA but the GOV Web Site only has a map and not many on it.
There was one in Gillingham, anyone know if it's still there or if there is another in Kent or nearest?
Cheers.
Time for a change!
theduck
posted on 23/9/15 at 02:45 PM |
The map is definitely wrong as IVA's are still being done at Kidderminster and it isnt on the list
Dick Axtell
posted on 23/9/15 at 03:41 PM |
Mine was tested at Kidderminster (2013). The tester there told me that that particular centre was going to close, but wasn't sure when.
Unless the site has been taken over by another (private) agency??
MrFozzieBear
posted on 23/9/15 at 04:34 PM |
To see the correct map view for the DVSA test centers that your looking for you need to click on the dropdown menu on the top left hand corner of the
map then select specialist schemes displayed as purplish dots.
Otherwise when you open the map it just shows Privately owned sites displayed as Blue trucks which don't apply for your test.
[Edited on 24/9/15 by MrFozzieBear]
theduck
posted on 23/9/15 at 07:41 PM |
I had test there in May and retest is on 12th October.
richardh
posted on 23/9/15 at 09:14 PM |
Nothing in kent as it seems that gillingham only does bikes.
In fact most don't do M1's which I believe is us kit car folks
Time for a change!
wicket
posted on 24/9/15 at 09:11 AM |
A lot of info here
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/277534/guide-to-the-iva-scheme.pdf
russbost
posted on 24/9/15 at 10:10 AM |
Edmonton are still testing at the moment, tho' apparently not for much longer, might be your nearest if Gillingham has gone - there was one near
Heathrow, but had a poor reputation as being nit picky, but never used it personally
SJ
posted on 24/9/15 at 01:27 PM |
I went to Edmonton and had a good experience, but that was back in 2006
russbost
posted on 24/9/15 at 02:10 PM |
I had a test with customer at Edmonton around 2 months ago, chap called Chris, very fair & helpful, but he did tell me Edmonton will be closing
fairly soon, I'm there in a couple of weeks with another customer, so may have some more info then.
