Fishface
posted on 9/3/05 at 01:45 PM |
RE: Ignition wiring
Im struggling with the steering column wiring. I have followed the spreadsheet which works fine but am stuck with the wiring for the ignition. Does
anyone have any photos or can point me in the right direction.
Rob
Fishface
posted on 9/3/05 at 01:50 PM |
Ive been looking at the mytigeravon website as its the best picture I can find and am wondering if im missing some wiring.
I am only using the tiger loom and a steering column which has the plastic original connectors removed. I have then plugged in the connecotrs from the
loom as per the spreadsheet. Should I have some kind of part harness from the sierra I should be using?
Thanks again
Rob
DaveFJ
posted on 10/3/05 at 11:59 AM |
Not got this far yet myself but I think you need a part of the engine harness from the donor according to what engine you are fitting.....
Dave
ayoungman
posted on 11/3/05 at 02:39 PM |
wiring
A lot of the original loom/connectors on the steering column are not needed. Remember, the light switch will be on the dash etc,.This will reduce the
number of connectors considerably. The ignition wires are more straightforward since there's fewer. I'll photograph mine this weekend if
its a help.
"just like that !"
ayoungman
posted on 11/3/05 at 02:59 PM |
engine harness
Sorry, engine wise, you need the small loom from the Black box.
From this loom you will need to make connections to the coil and ignition feed.
Search electrics section for plenty of details on pinto/avon
"just like that !"
Bananaman
posted on 11/3/05 at 03:03 PM |
I've got the wiring section from my Xtreme build if that's of any use. It is quite comprehensive regarding the column switches and the
black box wiring.
If you want a copy let me know and I'll scan some pictures in the morning. I can post a copy if you wish. No probs.
Michael
[Edited on 11/3/05 by Bananaman]
Fishface
posted on 14/3/05 at 08:30 AM |
thanks for all your help that it would all be grateful received. On a point of the black box, im actually not using it as I am using an alton dizzy
with an ignitor so dont have any wiring. I guess this may complicate it further.
Rob
