punker
| posted on 12/4/05 at 03:42 PM |
transit trackrod ends???
anyone know which transit the trackrod ends for the tiger avon front upper wishbones is from?
flak monkey
| posted on 12/4/05 at 04:00 PM |
I assume they are the same as any other locost....
EDIT; ooops wrong number...
Correct quinton hazel # for the drag link is:
QD1117RHT
[Edited on 14/4/05 by flak monkey]
Sera
http://www.motosera.com
Peter Cowley
| posted on 12/4/05 at 04:12 PM |
try ....dare i say it.... lolocost dirt cheap when I bought some off them for my westy.
flak monkey
| posted on 12/4/05 at 04:20 PM |
Problem with lolocost is the parts are cheap, but the postage is steep (£6 for postage!) They should only be about £5 each from your local motor
factors (I got a pair of Escort TRE's for £9.90 from Wilcos!).
Always worth saving on postage...
Sera
carlgeldard
| posted on 12/4/05 at 04:35 PM |
There are two tranny track rod ends M18 and M20 I think the M18 is the more common one. I think Northy told me his are the M20 ones from Tiger. Mine
are M18 but I made the wishbone myself.
Carl
punker
| posted on 13/4/05 at 08:22 AM |
i'm building my own wishbones as well but have already had the turned part made to acept the book "transit ball joint" , i went into
my local wilco but they said there about 4 different transit trackrod ends? i know they are m20x1.5 but which transit are they from?? also when you
made your wishbones did you make the jig from metal or wood and how did you cut your tubes to fit other tubes??
flak monkey
| posted on 13/4/05 at 08:39 AM |
The book transit rod ends are M18x1.5 not M20.
The AP Lockheed number is TA298 (according to the book)
[Edited on 13/4/05 by flak monkey]
Sera
punker
| posted on 13/4/05 at 08:54 AM |
yeh the champion book does but the avon book says m20x1.5 and says "the top wishbone ball joint is from the ford transit", just wanted to
know which transit?? thanks
carlgeldard
| posted on 13/4/05 at 09:12 AM |
I got the threaded tube from lolocost (I think) they cost about 4 quid then got the track rod ends from a local motorfactors. They fitted so I must
have been lucky.
The jigs that I made were made from 18mm plywood and Aluminium angle/flat bars all screwed together.
Carl
Viper
| posted on 13/4/05 at 05:20 PM |
The M20 joints are mk2 transit track rod ends
The M18 are transit drag link ends , either will fit the taper on the cortina upright.
I made steel jigs.
do a search on here for a little program called tube mitre this will show you how to properly "fish mouth" the ends of your round tubes
