marshall
| posted on 18/4/05 at 08:31 PM |
rad pluming
hi i am trying to plumb in the rad i have a pinto and a polo rad in place i have got 3 flexi hose pipes 2 for the rab and 1 for the
water pump the top 1 one fits ok the problem is joining up the bottom hose to the one from the water pump i know i need some metal pipping to join
together
hase anyone done this and if so have you got some pictures plz......
ayoungman
posted on 19/4/05 at 09:20 AM |
plumbing
You've got exactly the same setup as me ! I haven't connected up yet so I'm not much use ! I'll be keen to see your solution
though !
"just like that !"
clbarclay
| posted on 19/4/05 at 09:43 AM |
May be of some use.
http://www.locostbuilders.co.uk/viewthread.php?tid=10502
tom_loughlin
| posted on 19/4/05 at 10:49 AM |
im at exactly the same stage, and seems that there is very little help when it comes to plumbing these cars. i keep going round in circles!
is it necessary to have a header tank? just wondering.
tom
| posted on 19/4/05 at 12:23 PM |
I've just finished doing this in exactly the same way...
| posted on 19/4/05 at 12:24 PM |
and another...
| posted on 19/4/05 at 12:26 PM |
and one more...
I used some stainless tube, donated by a local fabrication company.
I also had to make a bracket/clamp fitted to the steering rack to keep the hose in the right place and stop it toucking the fan belt and steering
column.
Hope that helps, let me know if you want more pics/info as I found this part a right pain, so I know what it's like.
Nick
