shades
| posted on 8/5/05 at 10:43 AM |
Sierra diff mounts
Whats the crack with the rear diff mount? It is not mentioned in the book... I am assuming that only the two long bolts are required to holt it in
place... If so can i grind off the rear thread holes
antonyg
| posted on 8/5/05 at 11:01 AM |
i used the 2 long bolts and also welded on some brackets to support the front end just inside the transmission tunnel
didn't use the rear mount
Northy
| posted on 8/5/05 at 11:05 AM |
I made a rear diff steady for mine.
antonyg, aren't the nuts for the seat belts welded on the wrong side?
Graham
stephen_gusterson
| posted on 8/5/05 at 12:22 PM |
are there not 3 mounts?
I used the end mount as well.
I thik someone on here cut the end mount off, to find it was hollow and they had a big hole in the back plate (ned?)
whats wrong with leaving it as it is anyway?
atb
steve
antonyg
| posted on 8/5/05 at 01:43 PM |
yep they WERE until someone else pointed that out
that photos about 6 months old
Thanks Anyway for pointing it out
shades
| posted on 8/5/05 at 04:44 PM |
I'll leave it as is... Not sure as to whether I'll use the rear mount as a steady though
Mix
| posted on 8/5/05 at 04:52 PM |
If you are hard mounting the diff then by using the rear mount you can use the diff case to add rigidity to the chassis.
Mick
Lightning
| posted on 8/5/05 at 05:18 PM |
I certainly would put a rear mount on . Mine has become loose before
Northy
| posted on 8/5/05 at 05:36 PM |
Really?
Graham
tractorboy
| posted on 8/5/05 at 07:36 PM |
i only used the two long bolts and didn't bother with the rear mounting point. no problems so far.(famous last words!)
scott
