studon
| posted on 15/6/05 at 08:35 PM |
Cycle wing stays
Dear All,
I am trying to fit my cycle wing stays onto the cortina hubs on the three mounting points.
Problem I have is that there is limited flat surface at these point on the hub and the spacers I made are too large in diameter to get them to sit
properly. I would be keen to know how others have got round this.
Ta Stu
Humbug
| posted on 15/6/05 at 09:04 PM |
I got this pic from somewhere (can't remember where) and have used the same method, except that I have the head of the bolt on the inside. The
sequence goes something like:
Bolt head-washer-stay-washer-split washer-plain nut
then the run of the bolt
then plain nut-washer-hub carrier (htreaded hole)
I think I will have to cover up the bolt threads with something like heater tubing
Surrey Dave
| posted on 15/6/05 at 10:43 PM |
Wingstay
Mark Allanson
| posted on 16/6/05 at 06:58 PM |
I used 13mm tube to fill in the gaps, welded to the back of 3mm plate
