Author: Subject: Tiger suspension bolts
shades
posted on 18/7/05 at 06:27 PM Reply With Quote
I have just nipped up all bolts on my avons suspension... the 2.5 inch bolts will not give me 3 exposed threads past the end of the nyloc nut. Has anyone else had this prob? The bolts came with the kit. Think I might have to get 70mm long ones instead?
indykid
posted on 18/7/05 at 07:53 PM Reply With Quote
fristly, how nipped up is nipped up? i thought i had mine tight, but torqued them to 65Nm, and still got a reasonable amount more out of them.
even then, my bolts were still about half a thread short, but it wasn't checked at the sva. that doesn't mean it won't be, but i wouldn't worry too much, as long as a decent amount of thread is sticking through the nylon.
tom
shades
posted on 18/7/05 at 09:39 PM Reply With Quote
Nipped till they started to get tight. Prob just leave for the time being then. About to order wheels and get it off the trolly...
Mix
posted on 19/7/05 at 06:19 AM Reply With Quote
Thinner washers ??
Mick
DarrenW
posted on 19/7/05 at 08:34 AM Reply With Quote
This 3 thread "rule" always puzzles me. Im a time served engineer and have always wondered how the nut knows how many threads are sticking through??
imho, 1 thread thro and i would be cautious (due to tapers etc etc), 2 threads thro and i'd be happy.
Iam sure the 3 thread 'rule' applies more to the use of plain nuts and lock washers. Most OEM's use bugger nuts which are not as thick as nylocs. If you are concerned about a nut coming loose then mark them up with a line of paint and keep an eye on them during routine maintenance checks. Im sure the use of paint would please Mr SVA as this is std race car practice (as long as the paint doesnt show they have moved!!).
tractorboy
posted on 19/7/05 at 01:05 PM Reply With Quote
i work in the aircraft industry and we use nylocs .as far as i know you only need one thread through a self locking nut such as a nyloc.
scott
posted on 19/7/05 at 01:19 PM Reply With Quote
It's too easy to get hung up on this sort of thing - I like to see at least one non-tapered thread through the nut (the first thread is usually tapered a bit, sometimes the second as well). After that, the number of threads is irrelevant.
rgds,
DaveFJ
posted on 19/7/05 at 01:54 PM Reply With Quote
Agree with Dave -
although will say that when working on military helicopters we HAD to have a min of 3 threads showing or aircraft was unserviceable to fly....
Aircraft are always over engineered and overly cautious so maybe that is where this thing about 3 threads has come from ?
Dave
shades
posted on 19/7/05 at 10:42 PM Reply With Quote
Thanks guys. I'll not get hung up on it either and concentrate on stuff still to do...
DaveFJ
posted on 20/7/05 at 07:44 AM Reply With Quote
If it helps
I have had to use just one washer - under the nut - and have barely got a single good thread showing. with a washer under the bolt head as well there was no hope....
cheers
Dave
shades
posted on 20/7/05 at 12:42 PM Reply With Quote
Dave, I have done the same with just one washer under the nut. Would have liked to put the same under the bolt too, but not enough length...
Fishface
posted on 21/7/05 at 12:56 PM Reply With Quote
tightened mine up last night and struggled to even get one thread clear on some. I guess I will have to replace them with longer ones in the future before SVA
shades
posted on 22/7/05 at 08:20 PM Reply With Quote
fishface were they tiger supplied bolts too?
