Author: Subject: Extreme toe-out
andrew.carwithen
posted on 4/9/05 at 09:03 PM Reply With Quote
Extreme toe-out
Hi all,
Originally I couldn't get the front wheels to toe-out enough without leaving only a couple of threads still engaged in the track rod ends. (V. unsafe!)
No problem, I thought, contact Tiger and get a pair of track rod extensions as shown fitted in the book.
Duly arrived, fitted and now I have the opposite extreme of excessive toe-out!
I noticed, however, that with the extensions,locknuts and TRE's fully tightened up, there was about 10mm of exposed thread on track rods. So I have removed this to help shorten the rack but still have way too much toe-out.
As I bought kit second-hand I'm wondering if indeed its got the correct rack fitted in first place? (looks like other Avons though!)
Hence, I was wondering if fellow Avon owners could measure the width of their racks (inc. track rods) so I can compare to mine?
Many thanks,
Andy.
Lightning
posted on 4/9/05 at 09:08 PM Reply With Quote
You may want to hold fire Andy as Rob C and I are making wider wishbones for the front so that the track is almost that of the rear.
Northy
posted on 4/9/05 at 09:11 PM Reply With Quote
Oh, interested!
I was going to send my from wishbones to GTS so they could use them to jig up some wider fronts but it never happened last winter
Maybe this winter.
Graham
andrew.carwithen
posted on 4/9/05 at 09:23 PM Reply With Quote
Hello Steve!
Where you been hiding then!
Long time no hear on here or SWTOC!
Are you going to Ant's BBQ on 18th?
Interesting about the wishbones...will you have to fit a wider rack then (Sierra?)
Andy.
Lightning
posted on 4/9/05 at 09:33 PM Reply With Quote
Possibly
Just got back from Florida.
Has Ants BBQ moved date then? I'll look on the web site
Lightning
posted on 4/9/05 at 09:45 PM Reply With Quote
Disneyworld with the kids
Please note my South West Tiger Owners Club tee shirt
[Edited on 4/9/05 by Lightning] Rescued attachment dino.jpg
Northy
posted on 10/9/05 at 07:47 AM Reply With Quote
Lightning, any more details on wider wishbones?
Graham
Lightning
posted on 13/9/05 at 08:01 PM Reply With Quote
Not yet, we have the steel and are making the jig.
Monkeybasher
posted on 16/9/05 at 07:18 AM Reply With Quote
Is this to improve handling?
I always thought they looked like they could do with being a bit wider, especially as I cant get as much camber as I would like on the front.
I would be very interested in a set
Monkeybasher
posted on 6/10/05 at 10:17 AM Reply With Quote
Sorry a bit off topic but
How much camber can you guys get on your avon at the front?
I was hoping to run -1.5 all round but can only get -0.7 at the front. I think I will need to grind the wishbone a bit.
Also what are the standard spring rating of the GAZ struts.
Lightning
posted on 6/10/05 at 05:03 PM Reply With Quote
what youve got will do fine. I've got 1 degree on the rear and neutral on the front. The rear tyres are wearing on the inside. Track days don't help though
Monkeybasher
posted on 6/10/05 at 05:58 PM Reply With Quote
With -0.7 at the front, my tyres look like they are running quite a bit harder on the outer edge than the inner edge. The inner looks new after two track days. I dont run any toe in or out though front or back, I dont know if this matters. I just thought by the way my front left looked I needed more camber. I run 18psi and standard GAZ setup. The rears (-1) wear in the middle which makes me think the tyre pressure is still too high at 18psi.
Oh hang on just remembered you got a fireblade, being so much lighter must make the difference. Maybe I need stronger springs?
Lightning
posted on 6/10/05 at 09:00 PM Reply With Quote
Probably right. The weight must make a difference. My fronts are wearing evenly after 3000miles and 2 track days. A lot less weight though. I have slight toe in on the front.
