marshall
| posted on 19/10/05 at 08:17 AM |
speedo cable?
hi all i have just fitted a speedo cable to my car and i was woundering how do i know if it works or not the car is not going yet so i can not test
drive it that way
it is on a type 9 box and a 2.0 pinto the car is on axle stand at the mow .
has it got to be in gear or not?
donut
| posted on 19/10/05 at 08:32 AM |
If the engine runs then run the car and put it into gear. If it's plumbed into he speedo ok then all should be well. I presume you are using the
Sierra Clocks?
If the engine is not yet running then you will have to wait till it is.
marshall
| posted on 20/10/05 at 05:39 AM |
no iam useing tiger clocks as it is a tiger
i will have to wait until the car is running thanks
daz
| posted on 10/11/05 at 10:12 AM |
try using a drill on the end of the cable
