marshall
posted on 29/11/05 at 09:56 AM |
HEADER TANK?
Q: has the h/tank got to be full or half
full (or half empty ).
the tiger H/tank on a pinto is what i am useing
Howlor
posted on 29/11/05 at 10:13 AM |
Id go with half full. Basically the liquid needs to expand therefore if you fill it full it will hydraulic the cap off or worse still split the tank.
I would even go only a third or quater full as long as it still can build up the necessary pressure.
Tiger Super Six
posted on 29/11/05 at 10:51 AM |
I had the Tiger Pinto set-up and filled the header tank up to just below the line around the tank (kind of the mold line where the top and bottom
parts join).
Never had any problems.
Mark
Tiger Avon
smart51
posted on 29/11/05 at 11:36 AM |
I filled my header tank to the level of the highest point in the restof the coolant system. This happens to be half way up the header tank.
I've had no problems so far.
DarrenW
posted on 9/12/05 at 10:16 AM |
Just as an alternative idea ive not used a header tank and so far have no ill effects in my Pinto install.
If the header tank has an overflow it will find its own level, ie blow out any excess water.
Schrodinger
posted on 13/12/05 at 01:48 PM |
If the header tank is the one supplied by Tiger (Golf IIRC) then its marke Max - Min just above/ below the "seam".
Keith
Suffolk
Schrodinger
posted on 13/12/05 at 01:54 PM |
Keith
Suffolk
