pjavon
posted on 16/3/06 at 08:35 PM |
New Member
Hi all
I'm new to the forum but have built a tiger avon and have enjoyed it on the road and track for two years now.It's got a 2.0L zetec engine
which i have just spent all winter flowing the head, strenghening the bottom end and fitting piper 285 camshafts etc.
It's just been set up on a rolling road and she certainly goes now.
Next on my list are big brakes on the front and any advice anyone has would be helpfull. At the moment it's got a ford LSD with 4x4 discs and
calipers on the rear and cortina calipers with greenstuff pads on the front.
Also does anyone know where i can get extensions for the steering rack so i can extend the front wishbones.
I'll try to get a pic of my toy in the attachment
Thanks Paul
posted on 16/3/06 at 08:38 PM |
welcome along Paul - MK, GTS etc do track rod extensions.
andrew.carwithen
posted on 16/3/06 at 08:57 PM |
Hello Paul,
Lightning has just done that (fitting wider front 'bones to his Avon).
Have a gander at fairly recent threads on this section to find it. May help with any info you require.
Andy.
Lightning
posted on 17/3/06 at 09:16 AM |
here ya go
Lightning
posted on 17/3/06 at 09:24 AM |
BTW Andy just got a boot cover made locally at a boat yard. Made to measure and fitted in a day...£80. I think its quite dapper.
andrew.carwithen
posted on 17/3/06 at 04:47 PM |
Looks nice...I see you've changed your gear paddles 'n' all...D'yer make 'em yourself?
Lightning
posted on 17/3/06 at 06:31 PM |
yup
Also got air scoop at the side in Carbon fibre from Rob £5. Suppose its more that the packet of biscuits I paied for the stone guards
[Edited on 17/3/06 by Lightning]
pjavon
posted on 17/3/06 at 07:51 PM |
Thanks to you all for the comments.
I like the front end lighting, i like it a lot. Has it improved the turn in or is it not really that noticable?
Have you used the gaz shocks from tiger?
Mind you even if the answer is no to both questions it's got to be worth doing just for the look
Has anyone got any tips why i'm having problems uploading pics, managed to get 2 pics on but no more, then deleted them to try smaller size pics
but they still won't load
Paul
Lightning
posted on 18/3/06 at 08:06 PM |
Turn in deffo improved and had to get longer shocks.
