joolsmi16
posted on 18/3/06 at 12:07 PM |
rear hub
Hi all, very quick on are the rear hubs on the Avon handed? and whats the difference.
viatron
posted on 18/3/06 at 03:31 PM |
I'm fairly sure that the answer is yes, however i swapped mine around, as others have done, to fit discs braked rear and it seems to be fine.
Mac
joolsmi16
posted on 18/3/06 at 08:07 PM |
rear hubs
I've been look through the book and its seems that there is a offset of 10mm from the vertical on the drawings.
Now the drawing in the book is for the N/S with the 10mm to the rear of the car, so if I fabricate two identical hub carriers the O/S will have the
offset to the front of the car??
I have heard of swoping calipers so the flexi does'nt foul the wishbones?
