studon
posted on 27/3/06 at 08:49 PM |
Brake fluid crisis
Hi All.
I am now blasting my Avbon around now its got warmer. However I now have a problem with brake fluid escaping from around the master cylinder. Its
going everywhere!
The brakes are working fine and when I call upon someone to pump the brakes there are now visible leaks under pressure. I have pushed and pulled at
the fluid tank and cannot see any visible signs of leaks. Its a mystery!!
Any Ideas?
ta Stu
MikeR
| posted on 27/3/06 at 09:40 PM |
is there a pipe between the master cyclinder and reseviour?
if so, are you sure its brake fluid safe, fuel pipe doesn't make the grade!
COREdevelopments
| posted on 27/3/06 at 09:47 PM |
will it pass the sva with fuel pipe between the res and master cyl?
James
| posted on 27/3/06 at 10:44 PM |
Strangely enough, no!
Needs to be (cotton?) braided hose I believe and stamped as brake fluid safe (possibly with receipts to prove it IIRC.).
Hope that helps,
James
- Muhammad Ali
RazMan
| posted on 27/3/06 at 10:55 PM |
If the leaks are only appearing under pressure then you must have a dodgy union joint - check that you havent cross threaded a connector somewhere.
Raz
JAG
| posted on 28/3/06 at 08:15 AM |
This is probably escaping around the master cylinder reservoir cap - especially if you are driving enthusiastically
The cap on the reservoir HAS to breathe to allow the fluid to flow into the m/cyl'.
Hence there's an escape route if you overfill it or drive too enthusiastically.
Wipe it up and just keep an eye on the level.
Justin
studon
| posted on 2/4/06 at 02:26 PM |
It was the cap!!
Hurrah it's fixed no more brake fluid in the face!!
Thanks for all your posts
Stu
