ayoungman
| posted on 15/5/06 at 08:48 AM |
rear wishbones
After a long spell away from my build, I'm now in a position to make some more progress at last !
Anyone got a set of Avon rear wishbones going spare ?
"just like that !"
DaveFJ
| posted on 15/5/06 at 11:13 AM |
make your own... you'll be much happier than using Tiger items - and they might fit!
seriously the alignment is weird and they put a twist on the damper.
Dave
ayoungman
| posted on 15/5/06 at 11:24 AM |
someone give me the drawings and materials I need and I'll happily have go !
"just like that !"
DaveFJ
| posted on 15/5/06 at 11:31 AM |
the drawings in the book are a good start BUT... a little adjustment is needed. Best bet would be get a look at a set fitted so you can see where the
Your welcome to have a look at my car anytime but it's a bit of distance for you....
Alternatively Viper made some rear uppers to his own design and also moved the shock mount:-
  Rear end
Dave
VanHaydn
posted on 15/5/06 at 08:31 PM |
use a big hammer
smack the crap oot of iit or bend the shock mounts with crow bar... then fit the bushes in the wishbones then put some grease on the end of
your.....oops sorry spray some wd on the ends and gently persuade the wishbones in......
after all that dont ya wish ya got some other make of car hey?
Viper
| posted on 15/5/06 at 08:42 PM |
  Rear end
I made all the wishbones on my car because the tiger ones were so bad, also they were not made to tigers drawings....
(if tiger can't make the wishbones to there drawings who's to say they can draw???)
ps: forgot to say i made the uprights different to tigers as well.
[Edited on 15/5/2006 by Viper]
andyps
| posted on 16/5/06 at 12:48 PM |
replied to your post in the wanted section - I have some lower bones for sale
ayoungman
| posted on 17/5/06 at 12:37 PM |
Thanks Andyps, I've sent you a u2u ! Are you still at the same address? I've got your address from a previous u2u !
My main concerns are the hub carrier and the tap sizes for the rose joints. Do I need a left hand thread for one side of the car etc ?
[Edited on 18/5/06 by ayoungman]
"just like that !"
Viper
| posted on 17/5/06 at 03:57 PM |
All the threads are right handed...
ayoungman
| posted on 17/5/06 at 05:40 PM |
OK, so has anyone got a tap for the correct sized rose joint ?
"just like that !"
ayoungman
| posted on 22/5/06 at 10:04 AM |
i've decided to make my own top rear wishbones. Can someone give me a list of the materials and tools needed for me to fabricate them? tube
diameter and wall thickness etc.
Drive shaft carriers/hubs
Many thanks
[Edited on 22/5/06 by ayoungman]
"just like that !"
ayoungman
| posted on 24/5/06 at 10:03 AM |
Doh ! I've looked in the red book and its listed. I haven't opened it for over a year !
I'll fetch me coat
"just like that !"
