viatron
| posted on 26/5/06 at 12:17 PM |
Extra Long Eye Bolts
Has anyone fitted clip on shoulder straps to an Avon, Our Racer is nearly finished but we cant seem to find any eye bolts with thread long enough to
go through the crossmember behind the seat, fro memory the box section is 2" deep so would need an eye bolt with a 2 1/2" thread to give
enough to tighten onto. I have managed to find one lying around the workshop but everyone i talk to seems to think that 2" is the maximum length
made?????
Mac
[Edited on 26-5-2006 by viatron]
| posted on 26/5/06 at 12:46 PM |
Could you use an M12 eye nut and put a bolt into it from underneath?
procomp
| posted on 26/5/06 at 01:41 PM |
Hi 2" is the longest iv'e seen also . You will have to swap to a bolt in type harness . And is there a welded in tube through the
2" crossmember .
cheers matt
viatron
| posted on 26/5/06 at 06:33 PM |
yep there is a piece of tube welded in, dont know how using an eye nut would go down with the scrutineers? 2 1/2" definatley exist, ive got one,
but only 1 sob!
Mac
the_fbi
| posted on 26/5/06 at 08:42 PM |
If the slot in the harness bracket is 3" which according to the description it is, then this bolt isn't far short of 3" either.
Linky
