jimbona
| posted on 11/6/06 at 06:50 PM |
lower rear wishbone
hi everyone,
please advise... when fitting the rear lower wishbone what do i put inside the socket to fill the gab? the rose joint ( i think its called ) when
inside the socket in the chassis there is a good inch either side of the rose joint
many thanks
Avoneer
| posted on 11/6/06 at 06:59 PM |
A fistful of washers.
Get used to this method of spacing.
Pat...
| posted on 11/6/06 at 07:07 PM |
Or, if you have access to a lathe (or know someone who does) machine some spacers yourself
Phil
[Edited on 11-6-06 by Hellfire]
pjavon
| posted on 11/6/06 at 07:13 PM |
or maybe a bit of steel or ally tube cut to the right length
Always keep a big hammer and a condom in your toolbox, if you can't fix it with the hammer
t.j.
| posted on 11/6/06 at 07:17 PM |
pixxie on site from tiger
jimbona
| posted on 11/6/06 at 07:40 PM |
great guys. just wanted to check whether as I have purchased a bolt kit from Tiger that Im not spose to use a specific bit. thanks..
