jimbona
| posted on 11/6/06 at 08:25 PM |
fuel injection or carbs? !!
I need some advice please with engine details. What's the better option in the general, carbreter or fuel injection? I was informed one of
them is a lot more money altho u get a better sound and maybe 10/ 15 bhp more... is this true, is that the only difference?
I'm also aware that one of the two options requires you to cut out a hole in the body.. I think this is the fuel injection route.
Basically, im trying to decide what route to take..
thank you.
gary gsx
| posted on 11/6/06 at 08:40 PM |
Motorcycle carbs seem to be the way to go, well i am any ways
Chippy
| posted on 11/6/06 at 09:23 PM |
According to Burtons the BHP of the Zetec is pretty much the same whether you fit carbs, or PI. Chippy
Markp
| posted on 11/6/06 at 10:16 PM |
after having both, I personally would never go back to carbs
Mark
tom windmill
| posted on 11/6/06 at 10:31 PM |
i have heard up to 30 BHP gain from the bike carbs dont know how true it is the they make it go bloody fast
trogdor
| posted on 11/6/06 at 11:12 PM |
i guess it depends on what u think u can manage! carbs are fairly simple to use and set up, though they do have problems assciated with them! they
also require tuning etc.
fuel injection if ur doing it the locost way is more complex electronically as well as in the fuel system require fuel returns and high pressure pumps
etc. and people who don't understand electronics will find it harder to set up a megasquirt system for example.
personally i would prob use fuel injection on a modern engine, and carbs on a older engine. however i was planning to FI my v4 til i decided to
shoehorn an zetec in!
in this forum there is plenty of support for what ever method u go with so good luck with ur project!
[Edited on 11/6/06 by trogdor]
BKLOCO
| posted on 12/6/06 at 04:06 AM |
Ona aZetec?
No contest.
Fuel Inj every time.
+ points:
Increased power.
Increased fuel economy.
Fit and forget (once set up.)
Similar cost to twin carbs.
Much more reliable.
- points.
Can be a steep learning curve (if you have been brought up on carbs)
RazMan
| posted on 12/6/06 at 08:03 AM |
In an enclosed car like a middy, carbs often allow the petrol fumes to be a bit of a problem (ask any Ultima driver) so it's fuel injection for
me every time.
Raz
roadboy
posted on 12/6/06 at 08:09 AM |
Definitely injection, costly but much better economy, power & most of all smooth running.
Ian
Monkeybasher
| posted on 12/6/06 at 09:40 AM |
I too have had both, the weber alpha kit carb kit first on my zetec then I switched to gsxr throttle bodies on megasquirt. Absolutly no contest.
Injection ever time. Now on single throttle body with supercharger thats better still .
fuel injection is probably a little more work to install initially, but worth it.
jimbona
| posted on 23/6/06 at 04:16 PM |
ok thanks,
any ideas where I can get one or how much they are for a good buy?
are you going to say ebay?
