shades
posted on 4/8/06 at 08:37 PM |
Front toe in 9.5 mm or 2 mm?
Setting up my front toe in. Supposed to be 4 mm according to the book (2mm each side). Trouble is I can get it to 2mm (1 mm each side), but if I
turn one of the track rod ends through another 360 degree it goes to 9.5mm. Guess I leave as is or is there something else I need to do?
Adrian
JohnN
| posted on 4/8/06 at 08:57 PM |
Toe in/out is infinitely variable, just turn the rod that goes into the steering rack, don't turn the track rod end itself, leave it connected
to the hub assembly.
[Edited on 4/8/06 by JohnN]
shades
| posted on 5/8/06 at 07:15 AM |
Doh! yea see what you mean. I thought the sterring rack shafts were fixed, but do now recal them twisting as I tightened the locking bolts. Will
have another go today. Thanks for that
Adrian
