Rudy
| posted on 17/8/06 at 07:34 PM |
Damper extension
I had my rear damper too short so I try to extend with this. What do you think?
Does anybody try something like this before? If yes does it works fine?
Sorry for my English.
Rudy
| posted on 17/8/06 at 07:35 PM |
Another picture
DIY Si
| posted on 17/8/06 at 07:37 PM |
It might work if welded together. I don't personally think that bolting it will be sufficient to stop the bottom part moving. And you
don't want that!
Sun Tzu, The Art of War
t.j.
| posted on 17/8/06 at 07:39 PM |
i wouldn't use it bolted, there will be play on it. Only if you welded in maybe.
Aren't there longer coil-overs available?
Maybe you could lower the bracket by making a new one at a lower point?
By the way:
Did build the frame your self or is it tigers?
I was building by the book, but as the time growes it's getting less Avon.
[Edited on 17/8/06 by t.j.]
Nick Skidmore
| posted on 17/8/06 at 07:54 PM |
make a longer top eye for the damper
Rudy
| posted on 17/8/06 at 07:56 PM |
I think it would be hard to move. I put this picture.
If it mooves than I will weld it as you say.
I do not know what means frame.
In Italy you do not find this type of coilover
I buy it in UK.
If frame means chassis then is a Tiger LHD.
t.j.
| posted on 17/8/06 at 08:02 PM |
I think it will be moving, the extension won't be able to stop the moving
DIY Si
| posted on 17/8/06 at 08:04 PM |
The top of the point on the extension will quickly roll over and allow the extension to move upwards.
RazMan
| posted on 17/8/06 at 09:57 PM |
You will have to weld it - the leverage will try and rotate the extension and put strain on the whole assembly.
Raz
Phil. S
| posted on 17/8/06 at 11:20 PM |
Is that a protech shock? If so contact them. They do an extended top mounting eye that is 200mm higher than the standard one. I know because I changed
mine when it was too short. I have some pictures somewhere if needed.
"The unexamined life is not worth living" (Socrates)
"The unlived life is not worth examining" (Kopp)
Phil. S
| posted on 17/8/06 at 11:21 PM |
Is that a protech shock? If so contact them. They do an extended top mounting eye that is 20mm higher than the standard one. I know because I changed
Phil. S
| posted on 17/8/06 at 11:32 PM |
Here you go...
Rudy
| posted on 18/8/06 at 05:25 AM |
Thank you all!
