fideel109
| posted on 25/9/06 at 08:24 PM |
mastercylinder
Hello,
Which mastercylinder (make and type) can I use to build in my tiger?
My retailer doesn't seem to find a suitable type.
regards,
JP
James
| posted on 26/9/06 at 07:44 AM |
I used the one off the Sierra donor car.
HTH,
James
- Muhammad Ali
Fishface
| posted on 26/9/06 at 12:45 PM |
you have to be careful as they showed one on the original avon before they changed the chassis and the pedal holder assembly part. I had one of these
orignal types and it wouldnt fit properly. If you call sue shell let you know the right type. I ended up buying a new one from her in the end for
safety/hassle sake etc
Rudy
| posted on 27/9/06 at 07:16 PM |
In Italy I do not be able to find sierra MC pre 1987, so I do little modification and install a Fiat Uno MC. (Tiger MC pushrod with uno MC fit
perfect).
Sierra MC have diameter 22mm
Fiat Uno Master Cilinder have diameter 20.64 mm.
So I think if you have to modified bracket then use anykind of master cilinder, but remember sierra diameter 22mm.
Sorry about my English
Rudy
| posted on 27/9/06 at 07:18 PM |
Another image
