fideel109
| posted on 13/10/06 at 07:59 PM |
gearbox advice needed
Can anyone tell me which part has to be removed in the gearbox with the remote gearchange???
I've got a remote gearchange (Westfield model) from Tiger.
marcjagman
| posted on 13/10/06 at 08:06 PM |
Do you mean what has to be removed to fit a remote gear linkage?
fideel109
| posted on 13/10/06 at 08:08 PM |
Yes, thats my question.
Tiger Super Six
| posted on 13/10/06 at 08:23 PM |
There is a reverse stop that needs to be removed. It is on the right hand side (looking from the gear selector end up towards the bellhousing).
HTH
Mark
Mark
Tiger Avon
fideel109
| posted on 13/10/06 at 08:32 PM |
Thanks.
How is it fixed.
I assume it has to be knocked out???
givemethebighammer
| posted on 13/10/06 at 10:10 PM |
It is an interference fit, it's quite hard to knock out. I found the best way to get it out was to pull it out using a piece of m10 threaded
bar, a couple of nuts a piece of 5mm steel plate with a 10mm hole drilled in it and a 10 repair washer.
Basically lodge the repair washer behind the reverse detent (bit you want to get out), put the steel plate on the outside of the gearbox, put on the
second nut and tighten it up to pull the detent out.
Hope this makes sense (or yours comes out easily !)
[Edited on 15/10/06 by givemethebighammer]
DaveFJ
| posted on 14/10/06 at 08:34 AM |
I just levered it out with a BIG screwdriver.
you also need to remove the rear cover plate - that just pushes out .
hth
Dave
Rudy
| posted on 14/10/06 at 09:36 AM |
This is
Sorry about my English
fideel109
| posted on 14/10/06 at 05:33 PM |
Thanks for all your solutions.
But I guess I was lucky, it came out quite easily.
regards,
JP
