Author: Subject: Anyone use a heater in the garage?
shades
posted on 29/12/06 at 12:54 PM Reply With Quote
Is it just me or is it difficult to build up enthusiasim to head out to the garage? We seem to have had perma frost for the past two weeks.
Considering ordering a heater. Any advice on what kind?
Considering a "Honeywell Turbo Space Heater 2 Kw" from Screwfix that me and the dog can sit round...
http://www.screwfix.com/app/sfd/cat/cat.jsp;jsessionid=EQUCJCKPA4IN2CSTHZOCFEY?cId=102637&ts=96709
Adrian
graememk
posted on 29/12/06 at 01:00 PM Reply With Quote
i've got one of these from home base for £20
hobbsy
posted on 29/12/06 at 01:01 PM Reply With Quote
Hmm I might get one of those myself, fairly compact too at:
W x D x H: 160 x 260 x 240mm.
Might cost a bit to run though at full chat...
Hmm if leccy is roughly somewhere between 10 and 20p/kWh depending on plan, time of day, usage so far for that month then your looking at 20 to 40p/hour to run at full whack.
Not too high a price to pay to keep warm I suppose and you might not need it on high all the time.
Useful item to make up the minimum for free postage as well if you're like me and always need a few bits from Screwfix but hate paying the £6 or so for postage so end up ordering a load of stuff you don't need to spend £50 instead!
hobbsy
posted on 29/12/06 at 01:02 PM Reply With Quote
Whats the specs on that one? Is it Halogen? You need to be in line of sight to get the benefit with that or not? Could be a better option if you're tight on space like me.
graememk
posted on 29/12/06 at 01:07 PM Reply With Quote
yeah it dosnt heat the room just anything it shines on so as long as its pointing as you its nice and toasty, 2 or 3kwh i think.
i have a gas heater in my garage to warm the garage, and the halogen to warm me
stevec
Probably obvious but dont run it through a coiled up extension lead,
Steve.
tri
posted on 29/12/06 at 01:27 PM Reply With Quote
If you get 2 big lights and are working in the garage long enough they heat every where and if you do work
martin1973
posted on 29/12/06 at 01:35 PM Reply With Quote
i got a diesel space heater that i got secondhand a newark jumble,
bit iffy if your doing something with petrol of thinners,
also got a oil filled rad but costs some to run,
martin
macnab
posted on 29/12/06 at 01:53 PM Reply With Quote
remember not to close the door if using a space heater due to the fumes.
just read in the paper of 6 (I think) workers who all died in a container at a building site from fumes from a heater.
I have one and I just aim it at me (from a safe distance that is). Like the heat lamp though.
thunderace
posted on 29/12/06 at 01:57 PM Reply With Quote
i used a Halogen light last year was great i even done a brake change in the snow not by choice and i was kept warm also got a bit of a red face on one side with the heat.
(its a bugger when you brothers mot is in january and he know sod all about cars)
how much an hour do you think a 500w Halogen costs per hour???
thunderace
posted on 29/12/06 at 02:04 PM Reply With Quote
http://www.screwfix.com/app/sfd/cat/pro.jsp;jsessionid=HHX3ARCXII3H0CSTHZOCFEY?id=14558&p=x4&cm_re=CROSS_SELL-_-SLOT2-_-14558&catId=PRODUC T_DETAILS&ts=00981&destination=/app/sfd/cat/pro.jsp%3Fid%3D14558%26p%3Dx4#
posted on 29/12/06 at 02:37 PM Reply With Quote
CO poisoning from a generator is the suspected cause of the 3 deaths. I have a small propane blow heater but it's too hot to work with it on so I run it for ten minutes before I go in. 2kw is not going to do a lot unless you are on top of it but I also use a small £10 fan heater and put it behind me blowing wherever I'm working. It's handy for drying paint and filler as well.
shortie
posted on 29/12/06 at 03:10 PM Reply With Quote
My lamp like that was just the job, but as mentioned make sure the extension lead isn't still coiled!!!!
Melted Extension Lead_2
mistergrumpy
posted on 29/12/06 at 03:18 PM Reply With Quote
Holy Jeebus! That must've been lucky you spotted it in time to unplug it. A lesson to learn by all there.
shades
posted on 29/12/06 at 03:20 PM Reply With Quote
thanks guys, was avoiding propane heater for the reasons mentioned, and they also cause condensation.
Thinks will go for the electric one from screw fix and some new lights. Might consider insulating the roof for next year
Adrian
shortie
posted on 29/12/06 at 04:17 PM Reply With Quote
I was lucky that there was a circuit breaker on the garage supply, didn't stop me trying to turn it back on a couple of times until I noticed the smoke coming from the extension lead!!!!!
A lesson learnt!!
UncleFista
posted on 29/12/06 at 04:26 PM Reply With Quote
My vote would be for a pot-bellied stove from machine-mart.
They throw off an amazing amount of heat, they take care of their own ventilation, you can burn owt in 'em and you'll never need a bin
I have the smallest one they sell, in a brick shed/outhouse and it's excellent. Almost too hot unless your careful how much you load it..
Tony Bond / UncleFista
soggy 3
posted on 29/12/06 at 05:01 PM Reply With Quote
just wear more clothes .
or use a small electric radiator , i picked one up from a boot sale for a tenner.
[Edited on 29/12/06 by soggy 3]
wilkingj
posted on 29/12/06 at 05:02 PM Reply With Quote
NO NO NOOO!!!!!
Do it the Locost Way
Waste Oil Burner Heater
Best Regards
Geoff
http://www.v8viento.co.uk
andrew.carwithen
posted on 29/12/06 at 05:10 PM Reply With Quote
I use a halogen heater. It oscillates to throw out the heat over a wider area and warms up very quickly. Was cheap too (about £6 from local discount store!) though they're not normally that cheap (usually in region of £15 - 20.)
There's usually plenty on ebay (search under 'halogen heater')
Andy.
[Edited on 29/12/06 by andrew.carwithen]
Simon
posted on 29/12/06 at 08:23 PM Reply With Quote
When I extend my garage, I'm thinking of using one of those, with a very long chimney that goes up, then along, then up and along in the opposite direction, the with a long vertical section. Should act like a dirty greaty rad then
Might also have underfloor heating too
Simon
robinbastd
posted on 29/12/06 at 10:09 PM Reply With Quote
I've got one of those Honeywell fan heaters behind the counter in my shop....and it's pretty unimpressive.
Get a halogen heater as mentioned previously.
Ian
http://smuttygifts.com/
