shades
| posted on 6/1/07 at 02:01 PM |
How to wire the horn switch?
Trying to wire the horn switch on my steering wheel. The tiger loom has a long purple wire I have passed up through the Steering wheel boss.
Question is how do I do this without it coiling round the steering shaft? or is this normal?
Adrian
| posted on 6/1/07 at 02:18 PM |
the horn contacts on a sierra column (and probably most others) slide, so the wire doesnt have to move. It connects to the column iirc.
meany
| posted on 6/1/07 at 02:40 PM |
on early sierra's...is the horn switch on a column stalk and not in the wheel centre.?
shades
| posted on 6/1/07 at 04:19 PM |
Just dug out the old sierra steering wheel and there are slip rings on it, but there is nothing on the steering column cluster which mates to these
slip rings.
Think I might just put a horn push button on the dash instead...
Adrian
marshall
| posted on 6/1/07 at 06:16 PM |
i was going to do that but i changed my
mind and put a push button in insted it was easy to do ...
meany
| posted on 6/1/07 at 07:12 PM |
ill have a look at mine tomoz...its from a 1992 sierra
Rudy
| posted on 13/1/07 at 07:15 AM |
Hey Adrian,
this afternoon I will post some foto about what you need. If you have the ring you must have the brushes if not go to a scrap an get it. It is very
easy to to. the ring you have in old sierra steering well have to be fitted in new steering adapter, it will fit perfect.
Hope my reply do not came too late.
Sorry about my English
Rudy
| posted on 13/1/07 at 02:16 PM |
... you need this:
Rudy
| posted on 13/1/07 at 02:17 PM |
the brushes works on this ring:
