mark.s
| posted on 12/1/07 at 09:19 AM |
Lobro's and splined shafts
Hi all
has anyone on here removed the lobro flanges on the diff and replaced the shafts with the push in spline type...do they fit
cheers mark
PAUL FISHER
| posted on 12/1/07 at 01:37 PM |
Yes they are interchangeable,there's a big circlip that just holds the lobro in the diff from the inside,remove this,and the lobro just slips
out,you can then just slide the push in shaft into the diff,hardest job is removing the cover on the rear of the diff,the trick is put the diff in a
big vice to remove the casing bolts
mark.s
| posted on 12/1/07 at 02:40 PM |
i was hoping to leave the diff in the car paul...oh well as long as they change so i get a lighter back end that'll do me
cheers mark
[Edited on 12/1/07 by mark.s]
PAUL FISHER
| posted on 12/1/07 at 02:47 PM |
You should have no problem removing the casing bolts if the diff is still in the car Mark,its just that trying to get them out with the diff rolling
around the garage floor that can be difficult
mark.s
| posted on 12/1/07 at 03:31 PM |
  , i know what you mean
Wadders
| posted on 12/1/07 at 07:43 PM |
Just one word of caution, if the diff with the lobros is an LSD, the push in shafts wont fit (unless of course it's also an LSD) LSD shafts are
different lengths.
Al.
mark.s
| posted on 14/1/07 at 05:58 PM |
...that' buggerd it
when you say dont fit are they a different spline or is it just the length waders???
[Edited on 14/1/07 by mark.s]
