ayoungman
| posted on 7/2/07 at 09:55 PM |
heater unit fitted
Spent a cold day in the garage. Fitted the heater and made the expansion tank bracket and fitted it.
clicky
[Edited on 7/2/07 by ayoungman]
"just like that !"
tegwin
| posted on 7/2/07 at 10:23 PM |
That looks quite smart!
What heater unit is that from?
ayoungman
| posted on 7/2/07 at 11:06 PM |
Its from a VW Polo. I've made a flat mounting plate with four round outlets. Two feed warm air into the footwells, two go up to the demisters.
The footwell vents have closer plates so that maximum demisting can occur when needed. Here's a picture to show what I've done.
"just like that !"
James
| posted on 8/2/07 at 12:46 AM |
Looks really good!
Fantastic attention to detail by Mr. Youngman as usual!
ATB,
James
- Muhammad Ali
Rudy
| posted on 8/2/07 at 07:33 AM |
Well done.
I had copy your work.
Sorry about my English
macnab
| posted on 8/2/07 at 09:10 AM |
picture saved for future reference...
| posted on 8/2/07 at 12:30 PM |
A very neat job!
A qurestion - does your expansion tank connect into the heater loop from inlet manifold to water pump?
Also where are you planning to connect the expansion tank top outlet to?
Nick
ayoungman
| posted on 8/2/07 at 08:30 PM |
Yep, I've put a tee piece in between manifold and heater. The top expansion tube will go to the small pipe on the Polo radiator.
"just like that !"
