Author: Subject: ZX9-R what am I DOING WRONG?
longlife
posted on 21/7/03 at 05:04 PM Reply With Quote
Wired up Kwak engine, it does run beatifully,BUT, I can have ignition ON and petrol pump does not run, when cranking engine petrol pump does run. I know it's something electrical that I've done BUT WHAT?
mr loo
posted on 21/7/03 at 10:20 PM Reply With Quote
The bike pump will stop working when it reaches the required pressure and start again when the engine starts and use's fuel.try draining a bit of fuel out of the pipe and turning the ignition on to see if the pump works,if it does wiring's ok.
Rorty
posted on 22/7/03 at 08:00 AM Reply With Quote
mr loo's correct in as much as when the float bowls are full, the pump will cut out. They don't make a lot of effort either, it's something like 1.5 PSI.
What you may have done, is wired the pump on the wrong side of the ignition switch. It sounds as if you've got it on the starter circuit, and not on the ignition "run" circuit.
Cheers, Rorty.
longlife
posted on 22/7/03 at 09:50 PM Reply With Quote
I'll try Rorty's answer, thanks, have a Fosters on me.
