xico_ze54
| posted on 26/3/07 at 11:34 AM |
Fiat 124 Ball Joint
this photo seems to confirm the use of a Fiat 124 ball joint with the Cortina upright in a Tiger Avon.
I went in a shop that have some of that ancient material, but they asked to me what 124's ball joint is needed, upper or lower.
in fact, by the look in the drawings I saw in that shop, they seems to be almost equal.
so, wich 124's ball joint is used in the Tiger, upper or lower?
[Edited on 26/3/07 by xico_ze54]
| posted on 26/3/07 at 04:45 PM |
Really? Most use either the Cortina or the lower Maxi swivel....
xico_ze54
| posted on 26/3/07 at 05:00 PM |
that pic shows a Tiger Avon, and also a Cortina upright,
but that lower ball joint is not for sure from a Cortina neither from a Maxi, this last has only 2 bolts.
t.j.
| posted on 26/3/07 at 09:07 PM |
\they have both the same taper.
And yes they are FIAT 124 spider.
I use the lower. it si surely designed for it.
Only it has a spring in it. The upper don't.
So free choose there.
xico_ze54
| posted on 27/3/07 at 09:59 AM |
I thought it was from the normal Fiat 124. are they different from the Spider?
t.j.
| posted on 27/3/07 at 07:13 PM |
Now let's have a look in the book:
contina taunus ball-joint:
15.40 degrees
fiat 124:
top: 15,00 degrees (OEM 415 01 78)
bottom: 15,00 degrees (OEM 410 48 63)
fiat argenta:
top: 14,80 degrees
fiat 125 and 132
top: 14,80 degrees
bottom: 15,00 degrees (OEM 588 07 95)
All bottom joints are aftermarketed by SIDEM under no: 19183
BTW:
Sierra bottom: 14,00 degrees
Seirra 4x4 bottom: 17,00 degrees
Transit tie rod end
AVON: M20x1,50 RHT 15,50 degr (OEM- 1 481 651)
UNCLE RON: M18,5x1,50 RHT 15,50 degr (OEM 1 796 516)
upper balljoint cortina 15,40 degr. (OEM 6 010 076)
If thinking about porsche 911 bottom : 17,20 degrees.
No 124 spider?....no diverence there i think (hope ;-) )
xico_ze54
| posted on 27/3/07 at 07:34 PM |
great knowledges, T.J.
may be in Tiger they modify in the lathe the upright in a way to correct that 0.4 degrees.
BTW: do you know the Austin Maxi taper?
[Edited on 27/3/07 by xico_ze54]
t.j.
| posted on 27/3/07 at 07:50 PM |
That 0.40 isn't the problem, just fasten tight.
No maxi in my book.
Only (R)over group
Maxi 1969-1981 MArina 1972-1980 ITAL 1980-1985
lower king pin set 14,40 degr but no balljoint i think. (OEM GSJ 167)
xico_ze54
| posted on 27/3/07 at 07:56 PM |
many thanks t.j.
t.j.
| posted on 27/3/07 at 08:03 PM |
BTW
I have seen someone using a TOYOTA LITE ACE upright maybe availble around there?
up: 15,30 degr (maybe FORD's tie rod fits!)
down >10/1982 (4 bolts): 16,80 degr
down <09/1982 (3 bolts): 15,30 degr
Maybe you could check if it is useable!
[Edited on 27/3/07 by t.j.]
xico_ze54
| posted on 27/3/07 at 08:24 PM |
BTW
thanks again t.j.
I have two more pairs of Cortina uprights and still have an eye in some I use to see arround. its like an addiction to see amoung old cars where can
have a Cortina/Taunus
