pjavon
posted on 25/5/07 at 06:07 PM |
avon steering rack
Will the Mk1 escort rack fit the avon? somewhere in the back of my mind i think someone told me it had to be Mk2?
Can anyone held/confirm the differance for me
Thanks Paul
Always keep a big hammer and a condom in your toolbox, if you can't fix it with the hammer
DavidM
posted on 25/5/07 at 07:48 PM |
I believe Mk1 is imperial threads, Mk 2 is metric, otherwise the same, so shouldn't be a problem if you have the correct track rod ends.
24vseven
posted on 26/5/07 at 12:49 AM |
the main diffrence is as stated above diffrent threads
but the only reason this becomes a concern is mateing up corret tapers on the tre to the steering arm
however it is possible just got to find the correct track rod ends
mk2 racks are easier to find the track rod ends for
pjavon
posted on 26/5/07 at 07:49 AM |
Thanks for the help, probably easier just to buy a Mk2 rack then. Does anyone know what the ratio on the tiger quickrack is? as i have been told
it's £60 which seems quite cheap for a quickrack to me but i want one somewhere in the region of 2.4 turns lock to lock.
marshall
posted on 26/5/07 at 08:51 AM |
i was told by sue a tiger that a standerd
escort MK2 rack is no long enought and
has to made longer. but this was some time ago..
Avoneer
posted on 2/6/07 at 02:10 AM |
Yep - ends needs extending and come ready done by Tiger.
Not sure on the ratio of their rack, but it was fine for me on road and track.
Pat...
