edspurrier
posted on 26/5/07 at 02:30 PM |
Avon Zetec Cooling- Am I an Idiot?
Hi all. Struggling to understand the Zetec cooling pipes. Have Avon radiator, two alloy pipes, three bits of cooling pipe. I understand how they
should connect to each other to make the system work, but I can't figure out which kevlar pipe goes where. Can anybody please provide me with
pics of theirs? Likewise, how do you fit the little side exit pipe to the front?
Rudy
posted on 26/5/07 at 05:02 PM |
Please have a look here: http://www.zetec-cat.co.uk/
you should find what you are looking for.
Sorry about my English
Black Cat
posted on 26/5/07 at 07:08 PM |
I had the same problem with my Tiger Avon pipework, when I spoke to Tiher about it they sent me a diagram and it all became quite clear. If you
can't find it on the website as mentioned in the previous reply, let me know and I will post the info on here for you.
Regards Steve
edspurrier
posted on 27/5/07 at 08:31 AM |
I understand what connects to what - no problem there - but I have these preformed pipes which all seem to be the wrong size and pointing in the wrong
directions!
Schrodinger
posted on 27/5/07 at 12:38 PM |
Does this help?
Keith
Aviemore
edspurrier
posted on 27/5/07 at 06:50 PM |
Fantastic, thanks! Consider yourself owed a pint or two!
Not sure why they supply a hose for the water pump which doesn't actually point in the right direction. Preusme you have to cut it and fix it
together with the bit of metal tube - then worko out where to mount the T piece tube
Thanks again
Ed
[Edited on 28/5/07 by edspurrier]
Schrodinger
posted on 28/5/07 at 03:18 PM |
Layout is something like this, if you don't use the heater just install a pipe from the thermostat to the ally T peice or blank off both pipes.
[Edited on 28/5/07 by Schrodinger]
Keith
Aviemore
edspurrier
posted on 28/5/07 at 03:31 PM |
Got that, thanks - but why do they supply a hose for the water pump to T tube piece where the end points vertically up?
t.j.
posted on 28/5/07 at 04:42 PM |
One single hose on the engine?
Who made that drawing?
Schrodinger
posted on 29/5/07 at 11:16 AM |
As it has "Thermostat" on there as well as a separate item showing where it fits on the engine does it not make sense?
Keith
Aviemore
Schrodinger
posted on 29/5/07 at 11:18 AM |
I'm not sure I understand your question as the T tube can point any way you want.
Keith
Aviemore
t.j.
posted on 29/5/07 at 01:30 PM |
Just kidding
Don't take it too serious, probably i will use this drawing for fitting my hoses
Schrodinger
posted on 29/5/07 at 07:34 PM |
Some times it's difficult to know if somebody is or on here
Keith
Aviemore
edspurrier
posted on 29/5/07 at 08:03 PM |
Must be my build then - if I put the fat end of that tube on the water pump, to put the side exit pipe on the end would need either a hole in the
radiator or the engine block. Could of course just ditch that tube for a T piece as I'm not using a heater
