Ian D
| posted on 22/7/07 at 08:11 PM |
finish around the roll bar on an Avon
Guys,
Im struggling with how to finish this area. Does anyone have any photos of a good solution.
Ian
fideel109
| posted on 22/7/07 at 08:25 PM |
If this can be of any help
fideel109
| posted on 22/7/07 at 08:31 PM |
Oep, I've forgotten something...
http://www.locostbuilders.co.uk/upload/DSC00617.JPG
JP
Avoneer
| posted on 22/7/07 at 10:23 PM |
http://www.mytigeravon.co.uk/gallery/main.php?g2_itemId=139
Ian D
| posted on 23/7/07 at 04:48 PM |
Food for thought.
Black Cat
| posted on 30/7/07 at 08:08 PM |
Following on from Ian posting, will stainless steel button head A2 screws be acceptable to bolt down the roll bar with the SVA tester and should they
be sleeved through the box section?
Regards Steve
andrew.carwithen
| posted on 31/7/07 at 02:50 PM |
As my chassis is an early one, the upper rear shock mounting brackets are higher than on later chassis'.
Thus there is not enough clearance to get a nut between them and the box section to secure the foremost rollbar bolts.
I have placed the nuts inside the box section and bolted through the upper face of the box section only.
If your bolts pass completely through the box section then you would need to use crush tubes.
I believe that the minimum requirement is for 8.8 grade high tensile bolts.
I've used 12.9 grade cap-headed bolts.
Hopefully, that'll satisfy Mr SVA when the time comes.
Andy.
Black Cat
| posted on 31/7/07 at 07:07 PM |
Thanks for that Andy, but is a roll bar part of the SVA test or is it only part of the test when it is fitted and are A2 s/s screws bolted through the
box section with a crush tube OK. I understand that A2 s/s is not as strong as 8.8 bolts.
