Author: Subject: my progress (still earlyish in build)
jimbona2
posted on 3/10/07 at 09:34 AM Reply With Quote
jimbona2
posted on 3/10/07 at 09:37 AM Reply With Quote
jimbona2
posted on 3/10/07 at 09:38 AM Reply With Quote
jimbona2
posted on 3/10/07 at 09:39 AM Reply With Quote
posted on 3/10/07 at 09:57 AM Reply With Quote
looks good you need to get the moss out from between the paving!!
is chassis your won work?
Are the metal strips for the steering rack strong enough to resist flexing?
And the engine appears to be higher at the back - usaully it is the other way round - not sure if matters that much.
posted on 3/10/07 at 10:00 AM Reply With Quote
Is the engine leaning forward to clear the bonnet?? Looks a bit strange.....
jimbona2
posted on 3/10/07 at 10:01 AM Reply With Quote
na, its all tiger bits..
cant comment on whether the strips are strong enough although it feels okay??
got me worried about the engine now? where do you see it, the last photo I guess?
(i've done nothing because of xyz, i've just fittered it the way it fits..)
[Edited on 3/10/07 by jimbona2] Rescued attachment DSCN0325.jpg
jimbona2
posted on 3/10/07 at 10:09 AM Reply With Quote
posted on 3/10/07 at 10:18 AM Reply With Quote
The only thing I'd say is:
do you really want a tunnel-top mounted handbrake?
I put mine in the passenger area and I'm so glad I did.
I often drive with my elbow resting on the tunnel-top exactly where the handbrake would have been!!!
posted on 3/10/07 at 10:20 AM Reply With Quote
Oh- and keep up the goodwork!!!!!
jimbona2
posted on 3/10/07 at 10:21 AM Reply With Quote
yeah, i asked tiger about that, im just like you, its nice to put your elbow there but they said not to. besides, reckon going round corners sideways should really be with two hands
-- they said it affects your handbrake if its to one side because the two cables dont pull equally
jimbona2
posted on 3/10/07 at 10:24 AM Reply With Quote
on the engine thing, is it worth getting some stronger engine supporters, and whilst at it make it higher?
posted on 3/10/07 at 10:35 AM Reply With Quote
If you use the balancing half-moon type thing there is absolutely no reason IMHO why that last statement would be true
'tis true. for sliding round corners both hands on the wheel is usually a good idea... unless you're drifting it with the handbrake!!!
OH well! I know lots of people who like the handbrake being where it is on your car.... I'm just not one of them!!!!
posted on 3/10/07 at 10:42 AM Reply With Quote
it should be possible to drop the handbrake - pretty sure I have seen wells in the transmission tunnel that swallow up a lot of the handbrake.
If the well is too deep then it may be hard to grab the handle?
Surrey Dave
posted on 3/10/07 at 10:43 AM Reply With Quote
Midget / Sprite handbrake
Also in an accident a handbrake lever could really hurt you.
Follow Link For Photo:
http://www.groovy42.freeserve.co.uk/transtunnel.jpg
[Edited on 3/10/07 by Surrey Dave]
DaveFJ
posted on 3/10/07 at 11:57 AM Reply With Quote
your going to have to brace the steering rack supports mate. the latest tiger chassis uses a triangle welded against the side of one support. I have bolted a 3mm thick strap between the support and the chassis upright.
looking good
cheers
Dave
jimbona2
posted on 3/10/07 at 12:58 PM Reply With Quote
any chance of a piccy mate? thanks
DaveFJ
posted on 3/10/07 at 02:25 PM Reply With Quote
here is a crap piccy - but hopefully you can make out the reinforcing strap - cheers
steering
steering
[Edited on 3/10/07 by DaveFJ]
Dave
SALAD
posted on 3/10/07 at 04:51 PM Reply With Quote
Has your steering column crush section already been 'used'?.....Just a thought as I haven't looked at mine for comparison.....
jambojeef
posted on 3/10/07 at 05:56 PM Reply With Quote
You could call that an FAQ!
Its fine!
Hijacked it sorry...
Geoff
SALAD
posted on 3/10/07 at 07:04 PM Reply With Quote
That's good to know.....I shall sleep better at night now
jimbona2
posted on 3/10/07 at 07:50 PM Reply With Quote
whats this change needed for? new design from tiger?
andrew.carwithen
posted on 3/10/07 at 07:55 PM Reply With Quote
Like Dave, I have fitted a bracing bar to the rack mount brackets. I welded mine across both brackets and to the nearside chassis.
This is because some SVA centres apparently,have been failing the Avon due to the otherwise unbraced brackets flexing during operation of the steering.
andrew.carwithen
posted on 3/10/07 at 07:58 PM Reply With Quote
another view....(sorry about quality of pic) Rescued attachment Avon steering rack brace.jpg2.jpg
jimbona2
posted on 3/10/07 at 08:10 PM Reply With Quote
thanks, i'll look into it.
