Author: Subject: hand brake cable
jamrogers
posted on 20/12/07 at 09:36 PM Reply With Quote
hand brake cable
i'm fitting the hand brake cable and have cut off the rubber bit, the black plastic cone and the white plastic end, but am confused about how to attach the cable to the rear backplate should the nut secure it? if so how its on the wrong side of the backplate? Rescued attachment DSCF0034.JPG
build diary http://jamstigeravon.blogspot.com/
YouTube
https://youtu.be/JwwwilUd5Zo
Mr Whippy
posted on 20/12/07 at 09:48 PM Reply With Quote
looking at the pic, the clue is that nut and how the white plastic bit fits into the handy recesses on the back plate,
the nut would be on the wrong side cos you haven't taken it of the cable yet...
then again did you through away the - rubber bit, the black plastic cone and the white plastic end?
[Edited on 20/12/07 by Mr Whippy]
jamrogers
posted on 20/12/07 at 11:05 PM Reply With Quote
you can't get the nut off as it doesn't go past the ball on the end of the cable..... any other ideas?
YouTube
Avoneer
posted on 20/12/07 at 11:24 PM Reply With Quote
It just sits in the hole in the picture and the tension when you connect the cable to the pads holds it all in place.
Pat...
Aboardman
posted on 21/12/07 at 12:06 AM Reply With Quote
And if you can still get access to the nut after installed it will allow some adjustment assuming you do not fit the cable with the nut screwed all the way down the threaded section.
