Author: Subject: rear brake help!!
jimbona2
posted on 16/1/08 at 08:02 PM Reply With Quote
rear brake help!!
Hi everyone,
made some more holes tonight to feed the brakes through the rear seat panelling but somethings up..
for starters the holes I've created through the panelling dont really align with the chassis hoops.
am i going mad!?
[Edited on 16/1/08 by jimbona2] Rescued attachment DSCN0791.jpg
jimbona2
posted on 16/1/08 at 08:03 PM Reply With Quote
jimbona2
caber
posted on 16/1/08 at 08:14 PM Reply With Quote
Junk the Sierra back end and put in a capri, cortina or escort axle then the cables will hit the pick up points on the chassis! looks like an oopsy by Tiger!
Try and get into the tunnel around the side of the diff you will still have to reposition the handbrake and the cable pick up point further forward otherwise you will need to create a taller tunnel at the back!
Caber
PS handbrake was the worst part of my build and part of first SVA fail!
[Edited on 1/16/2008 by caber]
jimbona2
posted on 16/1/08 at 08:27 PM Reply With Quote
i cant make the holes lower than what they are as the chassis gets in the way (see second photo). if your saying feed the cables through the panel, below the chassis bar then i will have the opposite problem, i.e. the cables coming through the panel (using the holes that I create) will surely be too low....???
DaveFJ
posted on 16/1/08 at 10:25 PM Reply With Quote
problem is you have routed the brake line along the top of the chassis rail... the brake cables sit on the chassis rail and then 'just about' fit into the 2 tubes....
Personally i ran the brake line along the back of the cahssis rail to clear the cables but then had to dress the diff casing back a bit to ensure adequate clearance....
generally you need to build up the back of the tunnel top as well because the cables will stand above the line of the side rails.
HTH
Dave
DaveFJ
posted on 16/1/08 at 10:42 PM Reply With Quote
just been out and took a couple of piccies for you.....
Ignore the mess and the bent bit of panel! all things I have yet to get around to fixing!
Dave
soggy 3
posted on 16/1/08 at 10:51 PM Reply With Quote
I did mine the same way dave.
jimbona2
posted on 17/1/08 at 12:23 AM Reply With Quote
i see! you actually cut away the entire panel away whereas I currently have a hole, i.e theres a little bit of panelling left below the hole..
i'll have a look tomorrow if cutting the hole down entirely to the chassis bar whether it allows the cable to go through!
thanks, i will let you know!!
DaveFJ
posted on 17/1/08 at 11:22 AM Reply With Quote
As I say, the problem you may run into now is that your brake line runs along the top of the chassis rail and rill probably be in contact with the handbrake cables....
[Edited on 17/1/08 by DaveFJ]
Dave
jimbona2
posted on 17/1/08 at 11:39 AM Reply With Quote
might give it a go over the next couple of hours, any ideas what tiger does?
must be able to fabric something rather than just lying on the chassis bar.
i'll get a better idea when I can see it on mine..
DaveFJ
posted on 17/1/08 at 11:47 AM Reply With Quote
I did see one builder (can't remember who) who basically cut a piece if steel tube in half to form 2 channels and welded them to the chassis rail. These act as guides for the cable casing and protect them from chaffing on the edge of the chassis rail. they also protect the brake line beneath. which is a nicer solution form the engineering point of view....
Dave
Ian D
posted on 17/1/08 at 10:44 PM Reply With Quote
Mine are similar to yours. I have a picture in my photos. SVA-ing tomorrow so see how it goes. I built up the tunnel to accomodate the handbrake cables.
Ian
jimbona2
posted on 18/1/08 at 09:31 AM Reply With Quote
best of luck mate..
I cant see any really close up photos of the tunnel other than the rear head on photo showing the two cables coming out...
think im going to tiger tomorrow to get the exhaust package, will definitely have a good questioning session when im up there..
