bigbravedave
posted on 12/3/08 at 09:43 PM |
willwood master cylinder compatible fluid level sensor cap
Can anyone tell me if there is a brake master cylinder cap with integral fluid level sensor that is compatable with wilwood small master cylinders.
http://www.wilwood.com/Products/006-MasterCylinders/005-CSBMC/index.asp
I understand that there are kits to drill holes in my current caps but If I was designing master cylinders for low volume applications It would make
sense to use a tried and tested design of cap from someone elses! hopefully with a fluid level switch!
posted on 12/3/08 at 09:46 PM |
I can't remember if I've got Girling or Wilwood but mine took a standard Sierra type sensor....
twybrow
posted on 13/3/08 at 12:10 AM |
I picked up selection of ford caps with sensors in. They do fit, but the thread is slightly different. In the end, i used a hole saw in the Wilwood
caps, dismantled the ford caps, and installed them together. They cost me all of £1 from the scrappy!
[Edited on 13/3/08 by twybrow]
AvonBelgium
posted on 13/3/08 at 09:02 AM |
From fiesta or escort will fit
