Author: Subject: where to buy
jimbona2
posted on 31/3/08 at 05:42 PM Reply With Quote
where to buy
hi,
im going the throttle body route for my zetec but where can I buy the package, throttle bodies and all that fun stuff? or what bits make it up?
i know a bit more about what I need if I was going with carbs, i.e. the ecu, the 45 webers, the trumpets, wiring, gasket and inlet and exhaust manifolds but dont know anything about what I need for throttle bodies.
any knowledge on this appreciated!
thanks,
[Edited on 31/3/08 by jimbona2]
scotty g
posted on 31/3/08 at 06:00 PM Reply With Quote
Raceline.
Dunnels.
Burton Power.
Werner Van Loock
posted on 31/3/08 at 06:18 PM Reply With Quote
Jenvey throttle bodies if the pocket allows otherwise some R1 or GSX-R bike throttle bodies
A fuel&spark ECU, and again if the pocket allows a Weber alpha, dta, emerald, omex otherwise the common megasquirt or VEMS.
High pressure fuel pump with appropriate fuel filter, fuel return line, depending on throttle body setup a injection compatible fuel pressure regulator
And depending on your fuel tank maybe a swirltank (to avoid surges)
That's about it i think, other then carbs that is.
http://www.clubstylus.be
cossiebri
posted on 31/3/08 at 06:19 PM Reply With Quote
Emerald sell a complete package
Linky
Not locost though !
[Edited on 31/3/08 by cossiebri]
If it doesn't fit MODIFY it!!
Cheers BriF
posted on 31/3/08 at 07:10 PM Reply With Quote
Got my throttle bodies from Ely bike breakers for £65.00 , made the manifold myself although I had to pay someone to weld the ally , total less than £60. Respacing the throttle bodies was easy enough. High pressure pump, swirl pot , extra fuel line about £100 . Emerald ECU was a christmas present , sensors about £40 and a 36 tooth wheel £30 although as you have a Zetec flywheel and possibly crank sensor you shouldn't need that . Rolling road cost £275 plus vat but worth every penny. Megasquirt costs less but probably more hassle getting it set up ? Hope this give you some idea of cost . Not difficult if you do some research..
