Evrim
| posted on 19/6/08 at 09:56 PM |
rose joint bush material
Hi there,
I am making my slowly growing avon's rear bottom wishbones.I have my own lathe and i make my rose joint bushs myself from miled steel, but I
worried about that if the threads will strip out.Is the miled steel correct material or am i have to use hard steel?
blakep82
| posted on 19/6/08 at 09:59 PM |
mild steel is what rally designs ones are made of (i think)
and bear in mind you can get aluminium rose joints...
legends race cars 4 link bars are threaded aluminium tube
[Edited on 19/6/08 by blakep82]
________________________
liam.mccaffrey
| posted on 20/6/08 at 01:14 AM |
im doing the same as you, don't worry about it
Build Blog
Build Photo Album
Mr Whippy
| posted on 20/6/08 at 07:50 AM |
are the rose joints made of harder steel, doubt it
DaveFJ
| posted on 20/6/08 at 09:37 AM |
the size threads you are looking at, mild steel is well up to the job
Dave
t.j.
| posted on 20/6/08 at 03:42 PM |
I used normal steel (ST37) and have no worries,
grtz
Evrim
| posted on 20/6/08 at 03:46 PM |
Hi mate,
Thanks for comments.The rose joint material seems like hard material but not sure(bought from tigerracing?)The rose joint is 1/2" UNF and I
make drill hole 11.5 mm (according to the search from internet) the result seams ok.
t.j.
| posted on 21/6/08 at 04:55 AM |
As i'm on the continent i'm using a M12 one with a 12 mm hole. Mines are from SKF.
Greetings.
