jamrogers
| posted on 23/9/08 at 08:36 PM |
wheel alignment gunson trakrite
Has anyone used a gunson trakrite for wheel alignment? u drive over it and as the platform is on a roller bearing, the table rotates showing the angle
of alignment?
good idea or useless bit of kit?
[Edited on 23/9/08 by jamrogers]
build diary http://jamstigeravon.blogspot.com/
YouTube
https://youtu.be/JwwwilUd5Zo
JohnN
| posted on 23/9/08 at 08:57 PM |
I believe that for a production car, the basic ones that have fixed camber & castor by virtue of the suspension geometry, then the trackrite will
help with indicating toe in/out errors and the change in toe needed.
However, for a seven, without knowing that camber & castor are correct (or even what they should be) then it's going to be much less
useful.
I have one, and it has helped, but I STILL have no idea what my camber & castor measurements are or even what they should be.
One of these days I'm going to get it setup at a laser wheel alignment place to get some sort of basis to work from.
| posted on 23/9/08 at 09:21 PM |
Best thing for camber adjustment is a cheapo inclinometer off Ebay. The nice ones have magnets on the best so you can attach it to the brake disc.
Voila! Job done. Easy camber measurement.
For measuring toe-in the best thing (IMHO) is a decididly locost pair of tracking calipers.
At some point I really must do a tutorial on tracking using these things. I did it the other day and it's a PoP!!!
UncleFista
| posted on 24/9/08 at 01:46 AM |
They work fine, I've set up the Locost and a couple of tin-tops, several months later tyre wear is even with no handling problems. It paid for
itself in no time.
Tony Bond / UncleFista
loggyboy
| posted on 24/9/08 at 09:55 AM |
im in the process of making my own tracking bar. It will look a little like this:
with an adjustable threaded rod to measure the distance between front a rear most points on the front wheels.
It could also double as a camber measurer with some tweeks.
So far parts have cost under £40.
Mistral Motorsport
jamrogers
| posted on 27/9/08 at 02:37 PM |
i thought about making something like that but the bar would have to be quite thick to make sure it doesn't flex...
YouTube
