I have a steel tube supported at both ends. I am placing a weight in the middle. How do I calculate how much it bends?
Errm something to do with second moment of area? I can't remember. Deflection of beams was a while back!
there will be many factors length diameter, wall thickness, load it will be carrying
http://www.engineersedge.com/beam_calc_menu.shtml
ISTR for simple supports with point load smack in the centre
(W*L^3) / (48*E*I)
Where
W = Load
L = Distance between supports
E = Youngs Modulus for Material
I = second moment of area of cross section of beam.
[Edited on 14/6/10 by britishtrident]
your after 'beam deflection' equations.
see HERE
Bend it until it folds, then back a bit
Thank you. My top wishbones will extend inward to push down on inboard dampers. I wanted to know if I needed to reinforce them with a central member
in pure compression. They will bend by 73um laden but stationary rising to 3.2mm if the whole vehicle is dropped onto the front wheels at 10g.
Now I need to know how many g they will see in operation. Whilst 0.073mm is nothing, 3mm sounds like a lot.
one and a half times the diameter
I always thought you were supposed to stress for 3G.
I think 10G sounds rather a lot - there will be failures all round the car at that level.
I don't follow. 1.5 times the diameter of what is what?
10G would mean a 1.5 ton corner loading.
Your alloy wheel will never take it, never mind your sus arm lugs!
Unless you are planning a Dukes of Hazzard photoshoot, your car will never see 10G unless it's a crash.
For info on suspension loads, I've run strain gauges on the race car, the highest loads observed are around 6G vertical, this was only achieved
very rarely (in the region 10-20 occurances a season), generally only when the driver had placed the loaded wheel over a very significant kerb. I
would expect that for normal road use the pot hole loads would typically be lower, as you are relatively unlikely be hitting a pot hole whilst on
limit braking or cornering.
I would be more inerested in the maximium stress rather than deflection for abuse loads. I normally only bother with deflections at normal loads. I
abuse load cases extra deflection can be good for reducing shock loads placed on components further up stream, although this is always likely to
copromise goodperformance at normal loads.
Regards
Ian
Another question for you mechanical engineers out there if I have
80 x 40 x 2.64 rectangular box section this way up [ __ ]
30 o/d x 2.64 round tube 2 off side by side OO
Both 1400mm long supported at each end, point load in middle, same material mild steel
Which is stronger in deflection by what margin?
Hopefully people can work out what I'm after
[Edited on 20/11/10 by Minicooper]
Originally posted by smart51
Thank you. My top wishbones will extend inward to push down on inboard dampers. I wanted to know if I needed to reinforce them with a central member in pure compression. They will bend by 73um laden but stationary rising to 3.2mm if the whole vehicle is dropped onto the front wheels at 10g.
but it's fatigue over time that will cause a failure.
you are right, so long as you stay under the fatigue limit for steel there will be no failure by fatigue (theoretically)
the round tubes will be stronger in the current loading conditions,
the 2nd moment of area for and individual tube is 1.96x10e-7 compared to the 1.66x10e-7 for the square tube
meaning if you use two round tubes under the same loading conditions it will be approx 2.5 times as strong as the rectangular beam
however
using the rectangular bar "portrait" (as opposed to the landscape orientation it currently is in) it would be significantly better than it currently is giving a 2nd moment of area of 5.0x10e7 meaning it would be stronger than the twin tube setup
the loading conditions dont matter so long as they are the same for both round and rectangular, the only important bit is the 2nd moment of area
hope this is of help to you
courtesy of a 2nd year mechanical engineering student, so no guarantees for its accuracy, even though i am sitting an exam on it a week tomorrow
********edit to correct an error in the calculations********
[Edited on 2/1/11 by novacaine]
