IRS plans?????
JC - 20/10/05 at 07:25 PM
Sorry to raise this again, but are these the plans you're looking for?
http://www.georgecushing.net/SierraIRS.html
(If someone can post this as a link, do so)
And also here (don't know if these are the same as I can't view them!)
http://locostbuild.tripod.com/id30.htm
Hope this helps!
mangogrooveworkshop - 21/10/05 at 11:20 AM
http://www.locostbuilders.co.uk/viewthread.php?tid=33136
Why bother with all that when rortys got the dedion down on paper and it works less hassel and less to go wrong
Rorty - 24/10/05 at 08:58 AM
Even with the generous wall thickness of the De Dion tube etc. in my drawings , the De Dion set-up weighs in at just under 22kg whereas the IRS weighs in at 36kg.
Even the Chavs could comprehend the difference.
aweekes1 - 27/10/05 at 08:24 PM
Why bother building a car at all when you can just buy one? I'm going IRS route because I like to make things difficult for myself
britishtrident - 27/10/05 at 08:37 PM
I noticed the other day that although Aston Martin now share a floor pan with Jaguar the much more expensive Aston still use de Dion at the rear just as they have done since the early 1950s.
Peteff - 27/10/05 at 08:48 PM
I bet it's not the same one as they were using in the 50's really
britishtrident - 28/10/05 at 07:49 AM
I think they have a guy cutting them off old DB models giving them a quick coat of hammerite and stickig them on new Vantages. Trouble is demand exceeds supply so they have to share one axle between 3 cars.
