Would these fit on the standard Sierra hubs:
Linky<
br />
I know the off set should be 38. So if its 36 would they need spacer or have I got it the wrong way round
cant see 2mm makeing any difference, should fit ok. just make sure the centre hole is big enough for the sierra hubs
Hi Paul
I have just fitted 17" 7J TSW Heat wheels to my Indy with a 40 offset and they fit a treat.
The 36 offset will make the outside of the wheel 2mm wider than standard which is not a problem, my wheels are 3mm wider and they are fine.
My wheels came with sleeves to go in the centres to make them Sierra hub size. Might be worth asking.
Rob
[Edited on 21/7/2007 by RobH]
be careful, the listing says will fit ford or peugeot. the ford and peugeot fitments are ever so slightly different (the ford spiggot is slightly smaller) so unless they have the adaptors for both fitments they won't fit both! ask the question...
I've got those [with ET38 offset].
The wheels fit Peugeot without the spigot ring and ford with it.
Personally I wouldn't buy them again as the design of the wheel means that the spokes stick out further than the rim making it very easy to catch
them on a curb and damage them
I paid £289 for new ones with Yokohamas delivered.
Stu
They'll look fine Paul. Don't worry about making them fit, if the PCD's right we have the technology......
Bob
