my radiators started steaming once the engines warmed up, it should be sealed, its brand new, so theres no real reason for it...i tested it up to about 1.5 bar (very roughly) and there was only the slightest sound of air escaping...would it be okay to use it on this or will any extra pressure make it go bang?
well, it'll boil dry eventually at the very least...
where did you buy it from? send it back!
[Edited on 20/11/08 by blakep82]
its not too bad though, just a wee bit of steam...
it only started happening after a wee incident where the water pump breather pipe came off and emptied the contents of the system everywhere, just
after i gave the throttle a wee blip and turned ot off...there was quite a bit from the radiator too...it was after that i tested it...
Is it actualy leaking or just drying the water off the outside of the core after the spill
Radiators do tend to steam a bit after being drenched and then drying off…
Not adviseable to test at over 1.2 bar
Leaks show up more when antifreze is added to the coolant (because it reduces the surface tension).
Only certain way to locate a leak is to pressure test filled with coolant when cold,
The test has to be done when cold because hot water under pressure flashes off into steam which is is invisible.
However on modern alloy/plastic rads the only way to repairl a leak is to use epoxy.
The other way to stop a leak is to add K-Seal (NB K-Seal don't under any circumstances use Bars Leaks or Radweld)
I have Radweld in all my water cooled cars plus the digger and have done so for well over 10 years, never had a leak or any issues what so ever with
the stuff and also recently fixed Miss Whippys little corsa with it too.
great product
Now I'm curious I've always used radweld never had a prob. Pray tell me what's up with the stuff
I put radweld on my weetabix. I love it!!
Mine spews out the cap. Does this mean my cap needs replacing, or is there something else? It did it with no antifreeze and does it now with 50% antifreeze. Brown crap coming out as soon as the engine gets warm. Course, I haven't tried it since I put the fan on. Ideas??
I have Radweld in all my water cooled cars plus the digger and have done so for well over 10 years, never had a leak or any issues what so ever with the stuff and also recently fixed Miss Whippys little corsa with it too.
great product
