Anyone used an acewell digidash with the direct connection into the yamaha speed sensor to get the speed reading?
No one?
ok then, anyone even used an acewell in conjunction with an R1?
hello
Im using an acewell 2802 with an FZ1. couple of things:
I get the tach tango with the tach signal from the CDI. Ill take the tach signal from one of the leads to the coil, or simulate the exup servo motor
with a circuit.
The oil level warning light illuminates when grounded. The switch on the FZ1 engine opereates in reverse. I.e oil drained light is off, filled with
oil, light is illuminated.
Andrew
