I am wondering about the problems that I may have getting a BEC through SVA/IVA on carbs. I will need cats. Where can I get these and what problems
have others had in doing this? Is it worth getting an engine with injection?? Engine is ZZr1200 2004
Thanks in advance
[Edited on 16/1/09 by Lightning]
i passed on carbs...
you may need a bit of fiddling with them though
ditto,
got a local garage to set them up on their mot machine for me after failiing on my first sva on emissions
passed on carbs with a turbo!
How hard can it be....?!
I did, the second time. I needed a better cat. A bit of time on an emissions machine at the local Hi-Q got it set up. They didn't even charge me.
Me too, passed on carbs
I passed on carbs but my engine is 1990 so it's hardly difficult
Passed with ease on carbs.
Thanks to you all you have put my mind at ease. Down loaded the draft of IVA today to check on emmision values. I also have to check whether you need
a reverse gear, as today I called in at the sva station and was told that it did although I am sure I read that there was still no requirement. Bed
time reading 208 pages.
