Hi guys,
I just want to find out how you have fixed both ends of these cables? not to sure about how to do it. Pics would be mint!
Dave
pedal end attachment
.jpg)
It just so happens i have been dicking about with these in the garage all day today.
Accelerator I have a univeral cable with a nipple pre soldered on the end (TB end) and i have attached the other end with a screw nipple to a bracket
lick the one below
Clutch i have an MNR cable (thick 4mm) which i managed to break the threaded end off so i have just the same bracket/nipple/rosejoint combo i used for
the accelerator pics of the cluch install below
Bracket trial fit on cable:
Clutchcablebracketoncable
Bracket fit to pedal:
Clutchcablebracketonpedal
Please ignore the throttle cable in this picture as it is not the actual fit
Mine...
Cheers guys! got some ideas now.
Any more welcome!
Dave
theres some on my archive of how i did it...
Same as coozer for me.
I used the standard ST1100 cable so the carb end was easy
I stripped the other end to reveal the cable, drilled a hole through the end of the
throttle pedal and put the wire through. I used a grommet either side of the pedal to keep the wire from shifting. Coozer shows just one but on the ST
carb there's a bit of backlash so you need two grommets (you'll soon discover if you do if you go down this path). For grommets I used the
metal inner bits of chocolate block connectors. Cheap and easily available....
